pmilne avatar image
Remote VEConfigure won't upload.
I can download my Multiplus config through VRM and edit it in VEConfigure. But when I try to close VEC to upload the new settings it insists that a Grid Code is needed, although the Grid setting is 'No...'. So I can't alter the Multi. Any suggestions?
This only started recently and the only change might be a firmware upgrade.
MultiPlus 24/3000/70-16, firmware 401
VEConfigure 90.04.223
Pete
MultiPlus Quattro Inverter ChargerVEConfigure 3
pmilne avatar image
pmilne answered ·
Thanks seb71.
I can't tell if it uploads with no changes. VEC just closes.
I'd never touched the Grid code before it happened.
I tried to add ESS once but it was incompatible with the firmware - there are no assistants now.
Saving first makes no difference.
seb71 avatar image
seb71 answered ·
Does it work if you don't make any changes?
Have you made any changes to the grid code (even changing it from something else to None is a grid code change)?
Did you add ESS?
Have you saved the downloaded configuration (before editing it) or you opened it directly?
