ajhswan avatar image
ajhswan asked
When does VRM API login token expire?
Good Day,
When does the login token expire when you use:
POST https://vrmapi.victronenergy.com/v2/auth/login
I cannot see anywhere in the documentations that says when the token expires, it just says "If the token expires, an error message will be returned".
Thanks
Andy
VRM
Teun Lassche avatar image
Teun Lassche answered ·
It depends on the token type and whether remember me is checked etc.
But, the expiration is embedded in the token, you can use a JWT debugger to see the `exp` (expiration timestamp) in the claims: https://jwt.io/
