isagone avatar image
isagone asked
Color Control GX
Can I change the battery charger amps on my multiplus 5kva 24v
When I plug in my generator the multi is trying to pull to many amps out of it to charge the Batterys
Some one said if I buy a color control I can change this setting also have a 712 smart
battery charging
Alexandra avatar image
Alexandra answered ·
@isagone
Yes you can. You can then set the input current limit down to match your generator if it is set on the multiplus to be overridden via remote.
Your other two options are the ve bus bluetooth dongle and the digital multi control.
The other option is to reprogram the multi to only charge from grid with a lower amp draw
