bathnm avatar image
bathnm asked
VRM Now Displaying Temperature Probes on dashboard
I have just noticed that VRM is now displaying temperature probes. Looks Great.
However I have a temperature sensor reading 71.0oC, and what looks like a VRM/Device Instance 300.
I cant find what this in my system anywhere. Is it a bug? Is it a malfunctioning sensor somewhere within maybe my Cerbo.
VRM
Teun Lassche avatar image
Teun Lassche answered ·
Hi @Bathnm,
Your installation had some stale data from an old device. Fixed it for you
5 comments
bathnm avatar image bathnm commented ·
raphael avatar image raphael commented ·
@Teun Lassche (Victron Energy Staff)
I found a Bug:
After adding a temperature sensor and removing and disconnecting it again, it still displays at the VRM portal the last value. Right now I only have the Analog Temperature Input 1 "Temp. Battery LiFePo4" connected:
1624440862421.pngTemp. PV and Temperatur [26] are disconneced!
raphael avatar image raphael raphael commented ·
Do you think, you can look into that?
Once a Temperatur input was selected, it still showes in the VRM portal, even if I disable it again.
Kevin Windrem avatar image Kevin Windrem raphael commented ·
You probably have to remove the device with the "remove disconnected devices" (exact wording may be different) in the Device List menu
Then go to VRM and delete the device there.
raphael avatar image raphael Kevin Windrem commented ·
Thanks a lot! I did not see, that the temperature sensors are also a device...I could delete them in VRM. Thank you!
