Brian Knapp avatar image
Brian Knapp asked
BMV-712 incorrectly shows 100%; what do I do???
I updated the firmware whole the batteries were arou d 16-20% charged. It then read 100% after it updated.
I have two 200AH Lithium Ion batteries connected.
I am afraid of overcharging the batteries by manually choosing an estimated SOC, but I'm also afraid of over-discharging by NOT manually changing the SOC and them not charging above their current SOC because the system thinks they are at 100.
I guessed the SOC had charged to around 30%, so I manually changed it to that. Will a wrong guess damage my batteries as the system charges and then discharges???
What should I do???
BMV Battery MonitorLithium Battery
klim8skeptic avatar image
klim8skeptic answered ·
You should fully charge your batteries, with a quality charger that has been programmed with your lithium batteries' voltages.
Once your batteries are full, your BMV will synchronize back to 100%.
Brian Knapp avatar image Brian Knapp commented ·
Can I leave the charger manually set to 30% (my best guess about its SOC) before I charge to 100%? Or should I manually click the "Synchronize SOC TO 100%" button in the app before I try to charge to 100%?
I am very concerned about overcharging or over-discharging the batteries. If the SOC is set to 100%, but the batteries are really at 30%, will they continut to charge all the way up to 100%?
My BMV-712 and LiFPO4 batteries were set up by a company, so I assume they are calibrated correctly.
OP here. For context, this is how the batteries are set up in the Victron App under the BMV-712:81b358f1-57cf-4a1e-b12f-e82593f4ba1c.png
The BMV is just a monitor it doesn't "tell" the charger to stop because it thinks the battery is full.
The battery charger is working with a voltage based charging algorithm and doesn't care about the SOC measured by the BMV.
And as long as you don't have some cheap no-name china batteries they should have some kind of BMS that is stopping the charging if there is a problem.
Victron BMV battery monitors product page
