What type of temperature sensor is used on the Cerbo GX
Nickel 1000?
NTC?
PTC?
For Cerbo GX, the temperature sensor part number is ASS000001000 (the one without a fuse, which comes with some inverters).
Those ones are LM335Z
Hi @mike4nl
Do you have a wiring if this Temp Sensor hacking based on LM335Z please ?!
I try to make myself for my home CGX for monitoring inside and outside temperatures...
Thanks you vert much
29 People are following this question.
