andy-31 avatar image
andy-31 asked
Bluesmart IP67 12v/17a charger
Bluesmart IP67 12v/17a charger set to normal (14.4 volts) but outputting 14.7 volts. have reset to default settings to no effect (other bluetooth functions working happily i.e all info pages and changes to 12.8volts as a power supply) Is there some sort of reboot system or do I have a more fundamental problem? Much appreciate the forum, thanks, Andy
charger
ironman avatar image
ironman answered ·
szpieg avatar image
szpieg answered ·
This is quite normal behavior of the charger as the charger is voltage compensated - the voltage will be higher at low temperatures. The standard increase is 16.2 mV / 1 degree Celsius.
spanner avatar image
spanner answered ·
Have you tried to put on normal & recondition - which is 14.4 volts - see what happens?
andy-31 answered ·
Wow - thanks for quick reply. Yes tried that - still 14.7 volts!
spanner answered ·
Hmm - strange - how are you / what are you using to obtain the 14.7v display output from the Bluesmart - BMV?
andy-31 answered ·
Hi Spanner, output shown on phone (IOS) and confirmed on smartshunt (again via phone display). I also have a 5amp charger that works perfectly with same phone.
spanner avatar image spanner commented ·
Strange one matey - I've been looking back on the charge voltages from my mppt and Dc-Dc - and there are voltage spikes up to 14.6v but settles back down after a few mins, defo not 14.7v - So next suggestion is go into settings, and user defined, switch on expert mode, and manually enter the Absorption, Float and Storage voltage to see if this fixes it?
andy-31 answered ·
Will give that a go, thanks. Charger on boat so will report back after next visit
andy-31 answered ·
Thanks to everyone - Seems charger is smart and the operator is not! Had not realised how much difference temperature makes! Really pleased to have found this forum - thanks again.
