Hi
I got one cerbo go connected to a smart shunt and two mppts.
that’s all good but I also have tree more connected to another one, is there a way to get them to talk to each other? So I only get one panel in VRM?
Assuming it's a single system, connect all to a single Cerbo GX.
If all are using VE.Direct, you can use VE.Direct to USB cables and an USB powered hub (connected to Cerbo GX).
Hi!
Yes, But the distance between the MPPTs are quite long and hard to route.
23 People are following this question.
