nate-costello avatar image
nate-costello asked
Can the MultiPlus Compact temperature sense input be used for the Two-Signal BMS support assistant?
I am designing a system with a Multiplus Compact, which unfortunately does not have the two aux inputs like its larger siblings. For this design to work I need to provide a charge enable input using a third party BMS. In the past I have done this easily with the aux inputs and the Two-Signal BMS assistant. Is this possible with the Compact?
MultiPlus Quattro Inverter ChargerAssistants
Paul B avatar image
Paul B answered ·
Yes it can it should be just a closed or open signal
