milad avatar image
milad asked
Multiplus 1600VA and lagging on instrument
Hello everyone!
I am using a Multiplus 12/1600/70 with two 255AH batteries. Also, a 600W solar panel is connected to a MPPT 100/50. Also, I have a generator as a backup (3Kv Honda). A bmv is controlling the generator. It will turn on when soc drops to 50%.
The load is an instrument with 20A DC consumption. It is using 20A continuously.
The instrument is collecting data every second. I have some issue with lagging specially when the generator turn on. In this moment I have data every 10-20 seconds instead of every second.
The power assist is off on Multiplus configuration.
How can I fix this delay in the instrument. Should I turn the power assist on?
When the Multiplus is just invert from batteries and solar panels are able to charge the batteries, I don't have any problem.
I would appreciate if you could give me some advice.
Thanks in advance,
Milad
MultiPlus Quattro Inverter Chargerpowerassist
Justin Cook avatar image
Justin Cook answered ·
Hi @Milad, welcome to the Community!
I think we may need some more information about your system and some photos, perhaps, if possible.
By your description, it sounds as if your load is a DC load, in which case it should be connected directly to the battery bank and wouldn't have anything at all to do with the MultiPlus, so I'm assuming that this is not the case?
milad avatar image milad commented ·
It was our instrument not Multiplus. Because it happened at the same time with starting the Multiplus for the first time.
Thanks a lot for your reply and your time.
