boltman avatar image
boltman asked
Command Line using GX Touch 50
I just installed a GX Touch 50 on my Cerbo GX system (with the large image). I am able to ssh in to access the command line, but I would like to do it locally. I have a USB keyboard connected to my Cerbo. If I press "Ctl-Alt-Backspace" (which in linux normally exits the GUI), the GUI just restarts ("Restarting...).
How can I exit the GUI and get to the command line locally?
Thanks!
Venus OSgx device
bathnm avatar image
bathnm answered Ā·
It is not possible. If you want access then you can enable ssh and set a console password and connect via WIFI or Ethernet..
Here is the guide how to do this Venus OS Root Access
boltman avatar image boltman commented Ā·
Again, I'm able to access the command line fine with ssh. I can't believe it's impossible, since the command line works fine with a HDMI connection using a Raspberry Pi. I was disappointed that after upgrading to a Cerbo GX with a GX Touch 50, I lost the ability to execute commands locally.
0 Likes 0 Ā·
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
