serpa4 avatar image
serpa4 asked
SmartSolar MPPT 150/70 and BMV 712. Both are BT. Do I need a VE. Direct cable? If so, what does it add to functionality?
I have a new uninstalled BMV712 with BT and SmartSolar MPPT 150/70. I plan to use my phone/BT to see what is going on for charging, capacity, etc.
What purpose would connecting them both via a VE direct cable do? Would I gain any additional information? Do the two devices talk to each other over the VE or is this via Bluetooth?
I.e. should I buy a long VE cable and connect them?
VE.Direct
Paul B avatar image
Paul B answered ·
between the too items NO bluetooth is fine (make sure you setup the bluetooth network between the two items
HOWEVER if you also have a Cerbo or Venus or CCGX then a VE direct cable for each deviced is needed. as it gives more data readings to the GX device
