Could a victron technician please explain why my multiplus charges my battery below 5 degrees, when sensor tells 0 degrees. Multiplus has LFP mode enabled..
Multiplus will charge LFP batteries as long as BMS allows it.
I'm still trying to get my head around this.
My multi will temp adjust battery voltages..
My multi can enable/disable charge via temp port/software settings..
My multi CANNOT DISABLE battery charging based on its own temp port reading..
Very poor implementation of a basic required feature.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
41 People are following this question.
