Hi I’m looking for an assistant if available to shorten the time of which AC2 takes to connect on a mutliplus 3000 The system is used as a power assist only when plugged into shore power and all A/C loads are on AC 2
Thanks
Grant
Thanks
Grant
What you need is the "programmable relay" assistant. One to switch it on and another one to switch it off.
Fortunately you are not in the situation I am in (with a Quattro and two inputs) meaning you can easily program an assistant to do what you want. As Matthias said you need to use a programmable relay.
Examples of what I have tried is shown in the following post:
22 People are following this question.
