Jimmy Bergetun avatar image
Jimmy Bergetun asked
Modbus device ID for relay 1 and 2 on Cerbo
screenshot-2021-01-27-at-180710.pngI am trying to controll relay 1 and 2 from Home assistant with Modbus . In the Victron modbus tcp register it says com.victronenergy.system (Should be Device/slave id 100?) with address 806 and 807. In Home assistant i have added the following for this "switch"
switch:
  - platform: modbus
    coils:
    - name: "Victron relay 2"
      hub: victron
      slave: 100
      coil: 807
(All "Sensors" from victron works fine)
Anyone here been able to controll the relays on a Cerbo from HA ? Is the Slave ID and Address correct?
cerbo gxModbus TCPhome assistant
wkirby avatar image
wkirby answered ·
You are writing to a coil. There no available coils to read or write (eg. Function code 1 or 5), only holding registers to read or write (eg. Function code 3 or 6 (single register)).
You need to write to a holding register.
If you just want to control the relay 2 with a request, then write 807 to holding register using Function code 6 (write single holding register). Unit ID 100 is correct also.
4 comments
Jimmy Bergetun avatar image Jimmy Bergetun commented ·
Thank you !! :)
Juha Tuomala avatar image Juha Tuomala commented ·
I define the actual devices that I have as below:
- name: "Generator start"
  slave: 100
  address: 806
  command_on: 1
  command_off: 0
- name: XXXXXXXX
  slave: 100
  address: 807
  unique_id: 12435566778
  command_on: 1
  command_off: 0
  verify:
    input_type: holding
    address: 807
    state_on: 1
    state_off: 0
and when creating automations, I pick them for Action from Call Service as Switch:toggle XXXXXXXX on. It's much easier when modbus stuff is abstracted in server configuration.
Not yet sure will it switch it off once Conditions are not met (time) anymore.
subby28 avatar image subby28 Juha Tuomala commented ·
Where do I put this text in Home Assistant to allow me to control the relays? I have the Victron integration working ok.
wkirby avatar image wkirby ♦♦ subby28 commented ·
The best way is to create a file called /config/modbus.yaml and put your modbus related things in there. You'll need to reference the modbus.yaml file in your config.yaml with modbus: !include modbus.yaml
