innovasat avatar image
innovasat asked
Monitoring by Zabbix question
Hi; I'm trying to monitor a Victran MPPT (venus Gx) ... the issue is that it does not have SNMP and the device's monitoring interface is in the cloud as (https://vrm.victronenergy.com/installation / xxxxx / dashboard). It occurs to me that I can monitor a dashboard variable that indicates if it is working correctly, but I don't know how to do it. Where do I point in Zabbix, through the web scenario, or to another specific Item that captures that variable? Thank you. If you can think of an alternative way, tell me about it, please!
Venus OS
markus avatar image
markus answered ·
do you know Grafana?
This is a (very) easy to use alternative.
See here: GitHub - victronenergy/venus-docker-grafana
I know Zabbix, I did use that for server monitoring. But IMO Grafana is the better solution to monitor a Victron installation.
BR
