Martin Gasthuber avatar image
Martin Gasthuber asked
control CHP system by merging two control systems
just got the micro CHP (2kw on the electrical side) running and now facing a more efficient controling of that device. Both 'overflow' areas (soil based for hot water and heater for the electric part) are controled by an UVR16x2 from Technische Alternative. In order to get this running i need to export the SOC and state of the 3 Multiplus devices with a reasonable rate (i.e. once per minute) to the UVR16x2 to drive the logic and finally generate the signal to start (or stop) the CHP machine. The UVR16x2 could receive modbus data (my understanding of first reading on this). I'm wondering if someone has already done connecting a Venus (GX) with the UVR16x2 systems ?
best regards,
Martin
Multiplus-IIVenus OSModbus TCPchp
