info-4 avatar image
info-4 asked
conflicting meter readings
We inst626b65e1-5f32-47a3-bf30-70a3d582e903.jpginalled a smart meter at the main incomer on a 3 phase supply. We only have one Multi on L1, but client want to see usage over all 3 phases. Now the readings sometimes does not add up as per attached pictures
L1 uses 798W of energy but does not show from where...
Energy Meter
Paul B avatar image Paul B commented ·
what is the Remote control screen showing is it the same as It could be a delay in the updating of the VRM data fields, also look under settings and select the multi and see what the readings are there as well
info-4 avatar image info-4 Paul B commented ·
Thank you Paul
I unplugged the 3 ph meter from the Venus, and that sorted out the confusion. It looks like the Venus cannot process 3 ph info it you only use 1 phase on the Multi.
Paul B avatar image
Paul B answered ·
Answered by info-4
