Do you have a tip or solution to solve this issue ?
i only can see it on the Bluetooth App.....
Regards
Marcus
Regards
Marcus
Hi @PV Garage,
Thanks for reporting.
I have reproduced the issue and will get in touch with the team then report back.
Thanks for care.
I think I have the same problem.
I also do not get any solar yield displayed.
Have also thought at the beginning of a configuration error with me. Then I found this post on the blog.
My system has 3 MPPT RS 450/100 on VE.Can to charge the storage (14 kWh LiFePo). Otherwise works very well - only the display is somewhat reduced. Is it possible to get an indication when the problem is solved ? (Perhaps one notices it then also at the changed display without separate reference).
Here a screenshoot from the VRM,.... no Solarpower data..
No option, or solution for this case ?
No quick solution to this one, sorry. The VRM team is working on it.
OK, i have also a other issue... if want to switch back from only charging mode to Inverering mode, i become a error screen, you can see.....
It is also if i disconect all PV wiring. After i reset the inverter it works well....
Can you please create a new seperate question for that?
Inverter RS Product page.
Inverter RS Online Manual.
Inverter RS Datasheet.
22 People are following this question.
