pete-v avatar image
pete-v asked
Thickness cable IP65 12/15
I ordered the IP65 12/15. I wonder what the thickness of the cable (1.5 m) is... Because, 15A x 1.5m. x 0.2 = 4.5 mm2 diameter....That should be the thickness, correct? The connector cable with indicator leds (BPC900110114 or BPC900120114) is 3.3 mm2 in diameter and also 1.5 meter (see pdf) I was thinking to buy also the connection cable with indicator leds. If the cable of the IP65 12/15 is also 3.3 mm2, then, it's already too small, I think (should be 4.5 mm2). And certainly if I use the connection wire too... Then, 15A current is running over 3 m, needing a wire of (15 x 3 x 0.2 = 9) 9 mm2
So, what is the diameter of the original IP65 12/10 cable? And, can I extend that with the "battery inicator eyelet/panel"? What should I expect? Will it get very hot? Too hot?
Thanks
wiringip65
