Hello, everyone,
Is there a simple way to turn on a relay based on battery level? I have a load, which I would like to turn on when battery reaches 90% and turn off when battery reaches 50%.
Many thanks,
Peter
Hello, everyone,
Many thanks,
Peter
I am quite sure this could be achieved using the relay function on the BMV-172 - suggest looking at BMV manual to see if this would work for you....if you have a BMV!
Thank you for responding... Sorry I forgot to mention my setup. I have a Cerbo GX connected to MultiPlus, no BMV... It may be possible to do with the Cerbo, I'm just not familiar enough with it. The best way I thought of so far was to write a program to fetch the Remote Control screen and then screen-scrape the values for the battery, but it's all Javascript, which makes it more difficult to get to. There has to be a simpler way.
Hi @pbilka
Take a look at the Assistants in your Multi: https://www.victronenergy.com/live/assistants:start
There's a learning curve to use them properly, so not for the faint-hearted, but easier than coding. There's even webinars etc to help if you need.
GX - Generator auto start/stop
54 People are following this question.
