Bought new charge controller, connected panels. But the charger is not turning on.
I have checked all cables, fuses and rebooted.
i attach images
i attach images
What about the remote port of your mppt?
Is the link in place?
Any remote charge enable devices hooked up to the remote port disconnected?
I’m not sure what this means... could you explain? The mppt is Bluetooth?
You have 0V PV voltage. Check the polarity of the PV wiring.
To clarify- the charge controller has power, but is not charging at all, not even getting to bulk state. It appears there’s no input from panels at all.
Your Mppt can be powered by the batteries... no input needed from solar....to display mppt data....
Matthias is correct,, pv array is open circuit (disconnected) from mppt.
Your solar panels are not connected correctly (a loose connection somewhere or reverse polarity).
You have to check this.
Thank you
Checked connections again. One of the MC4 was not right. Replaced and it’s working now.
23 People are following this question.
