Alex Rodgers avatar image
Alex Rodgers asked
Quattro - utility and generator + ess
Hi All,
I am installing a small system 16x385w jinko mono + 2 x Smart Solar 250/85 MPPT + 1 x 8kVA Quattro + 2 x Solar MD SS4074 batteries
I would like to install the 8kVA Quattro - with 2 inputs - 1 x utility and 1 x generator, and run ESS, not to feed back into the grid, just to maximise the use of the solar.
The generator will auto start/stop with assistant on quatrro.
i have heard it is better to connect the generator feed to input 1 and utility feed to input 2 - how will this affect the ESS?
Looking for advice on this setup.
thanks
MultiPlus Quattro Inverter ChargerESSGenerator
