offshore avatar image
offshore asked
Lithium SuperPack 25,6V maximum number of batteries
i want to install 24x the Lithium SuperPack 25,6V batteries in parallel for one large bank with high current consumers like a 8000VA Quattro or a 450A hydraulic pump. (These batteries with integrated BMS)
There is no manual for this battery, only a data sheet- there is written parallel connection unlimited, so there should be no problem when each wire case the same lenght?
Thanks and Best regards
Lithium BatterySuperPack
marc-de-montreal avatar image
marc-de-montreal answered ·
hi, the warming that appear to me is that all of your batteries must be at the same voltage (or near of it) before to connect.. or connect one batt full charged at the time (on the first one already full charged)..
Marc
Battery Compatibility
