kennethknashaug avatar image
kennethknashaug asked
Please help with my Victron SmartSolar MPPT 150/35
I have a battery bank (48V) consisting of 8 x Fullriver DC400-6 (https://www.fullriverbattery.com/product/dc400-6/)
In the system I have a Victron Smart Solar MPPT 150/35, and I can't find any Battery preset that fit the Fullriver batteries:
I really need help to get this right, and believe "user defined" and "Expert mode" must be set.
Since I obviously are no expert, I need help with the following sections (in the app and battery settings):
- Bulk
- Absorption
-Equalization
- Voltage compensation
battery chargingmppt charging
michelg avatar image
michelg answered ·
Hi according to your information, setting from rotary switch number 3 should be fine. (for 48V multiply the values by 2, here the information is for 24VDC).
Hope it helps you.
kennethknashaug avatar image kennethknashaug commented ·
Hi. Thank you for answering, etting number 3 is close, but the recomended float charge for my batteries is lower than 55,2V. In the table you can see that this should be set to 54,8V. That is why I believe I have to set everything manually and in expert mode.
michelg avatar image michelg kennethknashaug commented ·
Hi, 27,6V x2 = 55,2V As you will have losses on the cabling, this shouldn't be an issue. Personnally I would go with the rotary switch on position 3, before starting to perform changes on the "expert mode". Remember that "equalization" must be DISABLED for your AGM Battery.
