jwfrary avatar image
jwfrary asked
Connect ve.direct bluetooth dongle and a ve.direct usb at the same time?
Ok,
I have a BMV 700 with a Bluetooth dongle. anyone got a methodology to get the data out to a ve.direct usb as well without pulling plugs every time to swap?
For want of a more elegant solution, I'm thinking a 3 pole changeover switch might do it if I cut the cables? - I'm hazarding a guess the ground could be common.
I use the Bluetooth to check the battery status from the shore. (Boats on a mooring) but I would like the data to go the the onboard signal k server when underway, which I then log in graphana. (I'm not aware you can use the bluetooth to accomplish that but maybe you can)
Thought I would ask, as I don't want to go cutting perfectly good cables up to experiment.
Thanks
VE.Direct
