Lionel SEYDOUX avatar image
Lionel SEYDOUX asked
low voltage alert
With about 30kWh OPzS batteries (24V, 1250Ah), SOC at 97%, T° minus 2°C and a multiplus 24/5000/230 feeding a fridge and a congelator (about 63 w for a short time every hour) , Not much sun these days but SOC always remain above 96%. Problem: the batteries voltage falls every now and then . Now 18.6V. so alerts and no communication for the last 6 hours.
? How can that voltage drop so low with such a small load?
? Or is my capacity much lower than what I think?
? or any other reason?
I have 320kWh bats (OpzS), Multiplus 24/5000/230, BMV712, CCGX, VRM (codes available) + 2m snow and -10°C outside.
More information as needed.
Thanks for some tips!
Lionel
low battery warning
Vangelis Beligiannis avatar image
Vangelis Beligiannis answered ·
Ηi! How are you charging the batteries? Do they finiah there absorption charge? Do you equalize them every 20-30 days? If not your batteries are slowly degrading.
Lionel SEYDOUX answered ·
Hmm.
Equalizing should be monthly, but I have not seen any sign of it recently (scarce sun);
Charging with victron blue solar MPPT. Rare absobtion finishing (scarce sun)
During sunless 3 days, SOC went down 3% with consumption 2kWh. With 24V batts that would make a capacity between 42 and 100 kWh (or 1876 to 4167 Ah) for a official 1714Ah C120. Am I wrong somewhere?
Thanks for your tips.
Lionel
Hi @Lionel SEYDOUX
Those voltages on a 24V lead-acid battery = a very empty battery!!
This is very harmful, I advice you to get your installer to check the system.
Your battery monitor is probably not configured correctly leading to a reset to 100% SOC long before the battery is charged. (or it is not installed correctly)
If you have a generator, I'd run it for a long time so the battery can get fully charged and equalized.
Thanks Dan !
In understand my 10 years old lead bats are done, but dont understand why no warning... I shall have to wait afew months before havin a look: about 2m snow, 3 hours to climb up with snox shoes. Safety is OK with a limestone pit under the batteries, but presently I am at -2°C. Will see and report as soon as possible.
Hi Daniël
I shall see to that BMV when I manage to come up there (no lift, 1m snow...) but un June, same settings I never came uneder 24.7V ar the end of the night.
