joan avatar image
joan asked
Error victron quattro 48/8000, low battery led.
  • Hello, let's see if anyone can help me. In the inverter the red low battery light has come on and the inverter does not work, in the color control screen the battery is at 100% and the voltage is 55.1V. The system has four 2.5KW BYD batteries and each has a voltage of 55V. In the terminals of the inverter there is also 55V. I have checked the CAN network cables from the batteries to the control color and they are correct, but from the CAN to the first battery that cable fails a PIN. I have replaced it but the inverter still does not start. Will I need to buy the MK2 interface to eliminate this fault? Any idea of the problem?
  • Thank you
  • img-20201230-wa0015.jpgimg-20201230-wa0014.jpgimg-20201230-wa0013.jpgimg-20201231-111855.jpgimg-20201231-111742.jpg
low battery warning
creeky avatar image
creeky answered ·
I have the same issue. Is there a solution? Some reset possibly?
