Is there a profile I need to set the IP67 battery charger to for AGM? I always thought AGM uses different profile than lead acid.
Thanks
Thanks
Depends on what your battery manufacture suggest for his batteries.
You have a few presets available but you also can change all settings to what your battery needs.
21 People are following this question.
Regular Interrupted During Charging BlueSmart IP 65 Charger
Blue Smart Charger permanent connection?
Blue smart 12/30 charger voltage/current spikes
Blue Smart IP22 update with temperature control & charging stop for LiFePo4 Batteries?
Terminals connections screw does not ajust anmyore clamper. How to solve?
