john-b avatar image
john-b asked
BYD B-box pro 13.8 state of health
I have two sets of BYD 13.8s with a 15000 Quattro and today have noticed the state of health of the batteries at only 66%. This is not a figure a looked at before but with the batteries being only 7 months old is there anything I should be doing to get them back to 100%?
I have solar and a generator to charge them. They were charging at the time I took these screenshots, initially at about 5kw (first pic) then higher current 10.7kw.
Lithium Battery
5 comments
Maybe the cells are out of balance?!
I would try to charge the batteries to 100%.
john-b avatar image john-b Matthias Lange - DE ♦ commented ·
Thanks for the reply, I will charge to 100% now.
john-b avatar image john-b john-b commented ·
It has just finished charge to 100% but still showing 66% state of health ?a8a1607c-68ca-44cb-bb9f-8c29f056b8fe.jpeg
Matthias Lange - DE avatar image Matthias Lange - DE ♦ john-b commented ·
Let it charge a while longer, it takes a while to balance the cells (if it is the problem).
If that doesn't solve the problem you should get in touch with the seller of the battery.
Ingo avatar image Ingo commented ·
I asked Freedomwon the question 'when should I be worried about SOH' and their reply to me basically boils down to the fact that it looks at a few variables and the biggest contributors seem to be cell balance and how often you charge to 100% or not. Just give it a few days to balance properly and do a few proper cycles back to 100% and I am sure the SOH will increase. Oh, according to Freedomwon, anything below 70% they would start looking at why that happens, perhaps BYD is similar.
john-b avatar image
john-b answered ·
A quick update regarding this issue, I have been working with Anthony at Bimble Solar and BYD and found that one of the BMS units was faulty which is why my SOH was down at 66%.
The faulty BMS unit has now been replaced and all is well, back to 99% SOH.
Massive thank you to Anthony Brennan who contacted me directly about this issue and helped diagnose the fault. BYD support is fantastic and very efficient .
It would be good to have the process of finding the issue is public in case of someone running into the same problem.
It was simply a case of isolating each battery bank individually and reviewing the SOH on each bank, one bank was reading 100% and the other 32%. We ran individual banks for a couple of days and monitored SOH. It was clear which battery bank was at fault.
BYD actually diagnosed the fault with the help of Anthony @Bimble Solar.
