It's been a while since i got "Real time data", just this link down error
Ok..I haven't had live data in over a month other than the "2-3 minutes data transmission.
It's usually network and internet related. Where we are the realtime monitoring also comes and goes.
What GX device do you have? What have you connected to it?
As already mentioned, what internet connection do you have?
If you have a weak internet connection and/or the GX device is to busy (many devices connected to it) the live data can be disabled.
I have a CGX. Yes all ports occupied (3 MPPTs) 1 Smart BMV12. But it worked well when I first set it up. Only this month's I've noticed live data rarely shows
I have the same results last couple of months.
After starting up the console the real time date is there!
I am sure something is changed on the Victron portal.
There have been quite a few VRM enhancements recently.
Please post a more detailed problem description in a new thread so it can be checked and passed on to the developers if necessary.
If you don't mind saying, your country may also help.
27 People are following this question.
