fab13n avatar image
fab13n asked
Controlling an external relay through VRM portal?
I would like to control a remote relay through Internet on my boat, and I thought it would be neat to be able to do it through the VRM portal.
I haven't bought any hardware yet; I'm willing to make the relay available throught MQTT, through a 433MHz link, or any other better-suited wireless solution. I can even try and remember some modbus bit shuffling if needed :-) The relays on my EasySolar-II GX are all available for now, if it helps. And I have a couple of old Pis and Arduinos lying around.
Is there a reasonable way for me to add a new toggle widget, or to creatively misuse an existing one, on VRM? Is there an easy way to capture those toggle events on my LAN?
(Notice: I have found the opposite on this forum, controlling the GX from custom devices, I'm trying to do the opposite here)
VRM
michelg avatar image
michelg answered ·
Hi Fabn13 ! I do remotely control 2 Windows 2012 servers using the 2 relays incorporated into the Cerbo GX.
As sometimes one of the servers just hangs up for no reason and that I can't wake him up using the WOL option offered by the router on which they are connected, I simply switch off the relay managing the concerned server, switch on, and everything reboots normally.
So yes, we can do several things with the Cerbo GX and VRM => Remote Control of the Screen, and then playing with the different parameters.
Michel
