My Quattro 48/5000 is connected to AC 1 with a Honda 2000i โAC1 current limit=15amp.
If I have a load of ~1400 W and my refrigerator starts, the load momentarily exceeds 15 amps and the โPower Assistโ cuts in as it should. However, instead of AC1 supplying 15 amps and the balance coming from the battery, it splits the load approximately in half with ~ 750 W being drawn from the battery. This is a problem when the battery is in a low SOC because it drags the battery down when it should be charging. Also, even when the AC load reduces to below 15 amps, the โpower assistโ is still activated and stays activated โand taking power from the battery--until the load is significantly reduced to say ~300W.
Is there anything that can be done to correct this problem?
