We are using multiple Victron IP68 Bluetooth chargers on a heritage railway, one for each carriage. Is it possible to change the displayed names when looking at the chargers using VictronConnect as the proximity of each one to the next is confusing?
Yes you can change the names, use the victron connect app and select the MPPT you want to change the name of and then select settings then product info (see red Circile in below picture). in here you can edit the name of the unit.
Many thanks, Paul - I eventually worked this out with one of the chargers and it's a great help. Updating to the latest firmware from the default made a big difference! Richard.
