I am installing new lithium batteries 2 X 12.8 200 amp batteries and there is a lot of extra kit that needs to be added. Can you extend cables like inverting on/off cable or temp sensor or + wire to the smart shunt?
As long as you are sensible with the extension length and wiring gauge used, yes you can. See note #3 in the temperature sensor overview: https://www.victronenergy.com/live/temperature_sensors
22 People are following this question.
