Screen inaccurate, bizarre reading like -1000 amps, -26kw with loads disconnected!
Odd symbols on screen. Firmware updated.
Can you make some pictures/screenshots?
For me it sounds like a defective and needs to be replaced.
Hi Matthias, these are the screen shots. NOTE start battery connected 24v showing 36v, SOC showing 0% when its about 80%.
I had a similar issue and it turned out to be the RJ-12 UTP cable. My unit was reading between 16 and 20 amps constantly, and zero current calibration didn't help. a new UTP cable solved my issue.
Turns out to be the shunt PCB, replaced shunt and all working!
Checked PCB to shunt contact surfaces, all looks fine. suspect it to be the actual comms plug on PCB.
25 People are following this question.
