david-zzzz avatar image
david-zzzz asked
How to disable loads on grid input feed
I have a 3 phase system using 15kW Quatros, my setup is ESS, PV is on the grid side (not through MPPT but through a grid tie inverter). I have a load on the AC grid side that i would only want to feed from the grid. As such the grid feeding the quatro's shall only be used for when battery is depleted and the minimium grid continious supply that is currently set at 1kW.
Can i eliminate this load that is being back fed from the Quatros and in turn from the batteries?
PS the energy meter can be moved. Will this solve the problem?
