lucy-laika avatar image
lucy-laika asked
Replacing a CBE CB 516 with a IP22
I am replacing a defunct CBE CB516 charger in my motorhome with a new IP22 12/15(1) charger. The old charger has a small single core wire on a separate terminal as a NET feed. It is labelled +12v . It takes a signal to the motorhome control panel to show that the charger is 240v powered on. As the IP22 only has one +12v terminal ,would it be ok for me to put the small 'net' cable into the same + terminal? Worried about damaging the new charger? Also if the 240v is off would this way of connecting always show it as powered on?
battery charging
sprintpeet avatar image
sprintpeet answered ·
I'm having the same problem. Any solutions would be very much appreciated.
