This is always on the display. I have changed the power cable on B1. Same issue.
I do see Current in and consumed.
I have 3 lead acid (for the moment), and have isolated 1 to test this voltage setup.
Hi @packerhiker
My guess would be that you connected the battery sense cable to the auxiliary input instead of the main input on the shunt.
I have made sure that it is plugged into B1 as instructed. It is plugged into the one closes to the multi-wire cable that goes to the meter.
22 People are following this question.
