Quick question,
is there a way how to wire Battery balancer alarm output to Cerbo Gx and configure Cerbo to remotely monitor if alarm raises?
Quick question,
I see this question was never answered and I too would like to know the answer.
Usually you would do this through the battery monitor, such as the BMV712 or Smart Shunt, configured to measure midpoint voltage.
Although the balancer can raise alarms, its alarm function provides no information to help resolve the problem, so when an alarm goes off, you're faced with trouble shooting. AFIK, the Cerbo won't be able to use the alarm relay.
Yes you can wire the ballancer alarm output relay to one of the digital inputs on the cerbo and configure it as alarm input. I have done just that and it will alarm on the touch screen locally as well as in vrm.
@derrick thomas Can you tell us how you did that in the setup of the garbo GX please
25 People are following this question.
