patr avatar image
patr asked
CCGX no longer recognizing SD card
I have an SD card in my CCGX and it was working a month ago. Now, on the 'VRM online portal' screen I see the line
microSD/USB No storage found
When I am off shore and have no internet connection my data does not get stored so that when I get back and connect to VRM, there is a gap in the data.
How can I fix this?
thanks
Pat
battery charging
Have you tried safely ejecting and then physically removing it, and reinserting it,
Then try formatting,
Then try replacing the SD card.
Then try using a USB stick instead of the SD card and see if that has the same issue.
They also do wear out over time - I've had to replace the SD card in my dash cam before.
