james-yardley avatar image
james-yardley asked
Does VE-BUS BMS protect against LOW temperature situations
Hi all,
After a definitive answer on the above please, we have 4 older (non Bluetooth) Victron LifePo4 batteries daisy chained to the BMS and I know that it will stop charge and draw on a high temperature event, but what about cold temperatures??
Can anyone let me know please?
Many thanks in advance!
Lithium Battery
hendrik-jan avatar image
hendrik-jan answered ·
The old non Bluetooth batteries do not have a low temperature protection. The VE.bus BMS also does not protect against low temperature. So the system will continue charging while it is freezing.
The Bluetooth batteries have the 5 degree low temp charge protection.
james-yardley avatar image james-yardley commented ·
Many thanks for your quick reply... ok, am I correct in thinking that a way around this is to use the BMV's alarm replay and a temp probe on the battery?
