david-kessner avatar image
david-kessner asked
App says Orion Smart charging is disabled, current meter says otherwise.
My Orion Smart 12v/12v-18a charger is set up for LiFePo4 batteries. The iPhone app says charging is disabled, but my clamp-on current meter shows 10-15 amps. If I flip the remote switch, the app reports that immediately so it's not a Bluetooth connection issue. I've verified that the current meter is working, and I've power-cycled everything (including the phone).
If I turn off charging via the remote switch, I see the current go down to zero. So that's working at least.
Thoughts? Ideas?
battery charging
Paul B avatar image Paul B commented ·
The information you have provided is not enough, please send some screen shot pictures of the setting in the orion smart unit. plus voltage readings and current readings. as much info as you can please.
