I have observed that on windy days my VRM generally reports fairly high PV yield. I was wondering if the output from my wind turbine is getting added to the energy of the solar panels in the VRM reports?
More infor is needed. Ie how is the Wind generator connected to the GX device, if its add as a solar device then yes it defiantly would
The wind generator and the MPPT’s are both connected directly to the charge busbar which then feeds the battery via a Battery Protect controlled by a BMS. The MPPT’s are connected to the GX using VE Direct. The wind generator is unknown to the GX. I guess the question is whether the GX is aware of the charge produced by the wind generator and if it is how does VRM report it?
24 People are following this question.
