victorvictron avatar image
victorvictron asked
Storage help for new LiFePO4 battery
Delays caused by the pandemic have left me with a brand new Victron LiFePO4 200Ah battery that won't be connected until the rest of the system components arrive. Unfortunately it's now been 3 months sitting in the box and could be there for another 1-3 months until it's installed. How long can new batteries be left unused before degrading or being damaged and what should I be doing during this period to keep it healthy? I've been checking the voltage once a fortnight with a multimeter, it currently reads 13.32V which hasn't changed since its arrival 3 months ago.
Lithium Battery
Paul B avatar image
Paul B answered ·
Hi If it drops below 13 volts then charging it be helpfull just for piece of mind for yourself
using a standard car charger is fine top it upto 14.2 volts and then if and when it drops below 13v top it up again
Really you have nothing to worry about unless the voltage got as low as 12v then its really time to charge the battery. These dont loose much power in storage at all.
victorvictron answered ·
Thanks Paul
Hi @VictorVictron
13,2 volt is perfect, they can be stored for a long time like that.
What you do want to do is connect to them with VictronConnect to make sure they have the latest firmware inside, the latest firmware makes them store-able even longer.
Thanks Daniël I’ve paired the battery with the app and updated the firmware to v1.19 as suggested. Here are my new battery’s stats. Will this be fine as is for long term storage? 79f6987c-cd2e-4d68-b658-94e6693cffea.jpeg
