Ryan1 avatar image
Cyrix-ct with solar charge controller
I have a Victron 75/15 MPPT solar charge controller, which I want to use to charge two banks of batteries on my boat - the house batteries (410Ah of Trojan deep cycle) and the starter battery (a fairly standard engine starting battery about 80Ah). To split the charge from the controller is the Cyrix-ct suitable?
MPPT - Solar Charge ControllerCyrix Battery Combiner
Rob Fijn avatar image
Hello, yes you can do this as follows.
Additionally you have the Start Assistant function.
If the Sun is down or rainy day, then the Alternator will charge both battery's
If the Sun is down or rainy day and the engine is not running, then the DC loads will only be powered from the Domestic battery and the Starter Battery will not be discharged.
Best regards, Rob
Share
Gary Cantigneaux avatar image
Dear,
Thanks a lot for this post as this is exactly what i wanted to know, however, if i read the circuit correctly, does this mean that the solar panel will also charge the second battery? i cannot recall that my MPPT had two outputs.
Furthermore, can you add to the diagram how to connect the battery charger?
Thanks for the clarification.
Gary
Share
