mvader (Victron Energy) asked
Venus OS v2.62~3 available for testing
Good day to all,
Just now we released v2.62~3 for field testing. It fixes an annoying regression introduced per v2.62~2 as well as some other open ends. Details below.
This post is intended for all people participating in the Venus OS Beta test program.
Changes (compared to v2.62~2)
  • Fix bug that caused VictronConnect to indicate that a firmware update is required when accessing a product remotely through VRM. The problem was introduced in v2.62~2.
  • MPPT RS: Add logging of individual tracker data to VRM (still needs completion on VRM itself, for now the data is only available on the diagnostics page as well as in the download available on the advanced page).
  • IMT Solar irradiation meter: Fix reporting of negative temperatures
  • Fix bug in previous fix for race condition between BMV and systemcalc that caused consumption not to be logged in some cases (only seen on a raspberrypi, more info here).
  • Send the the setting (enabled/disabled) of the Node-red as well as SignalK services (part of Venus OS Large) to VRM, will be used to hide/show the links.
All the best,
Matthijs
Venus OS
8 comments
connect access via VRM working fine now.
thanks
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ nickdb ♦♦ commented ·
good! thank you for confirming.
Mark avatar image Mark commented ·
e9df2f8f-af18-41e0-a1ad-bb550a3891e1.pngHad this twice in the last 2 days..,connecting local on victron connect !! V2.62~4
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ Mark commented ·
Hi, are you really sure this is with v2.62~4, and not with v2.62~2?
since an issue just like this was fixed in v2.62~3.
Mark avatar image Mark mvader (Victron Energy) ♦♦ commented ·
Hi Matthias,
had this issue originally connecting remotely, latest release candidate fixed that issue,but while connecting local have had this issue Today, Just to confirm v.2.62~4
Hi, ok, what do you mean with connecting local? You mean over Bluetooth?
And what version of VictronConnect are you using?
Connecting locally over Bluetooth.......
App version.....v5.36beta2
jperez (Victron Energy Staff) avatar image jperez (Victron Energy Staff) ♦♦ Mark commented ·
This is a bug in v5.36beta2. You can workaround it restarting VictronConnect or also pressing scan button and waiting ~10 seconds before connecting again.
Early next week we'll release VictronConnect v5.36beta3 which fixes this issue.
n-dee avatar image
n-dee answered ·
Right now I'm not able to connect to my cerbo via vrm portal.
Flashing back to 62.2 doesn't solve the problem - so maybe coincidence and the problem is somewhere else.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hi n-dee, yes - last night we had an issue in vrm, should be all solved again now
Mark avatar image
Mark answered ·
Possible bug!......
GX GSM stops transmitting data every time V2.62~4 is uploaded.....(geofencing & remote access is non responsive!)...every time I revert back to latest release,the problem disappears!
Hey Mark, we tried to reproduce this (with v2.62~7) and couldn't. Could you confirm if this is still an issue for you?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ mvader (Victron Energy) ♦♦ commented ·
Discussed offline and solved per ~11
