Lasse Federley avatar image
Lasse Federley asked
When will Victron start to supply a AC to DC regulator for windturbines?
you can use the DC to DC charger with a windturbine. I connected my 400W AC wind turbine to a rectifier. The output I connected to a spare 200Ah battery. From there I took the input to the DC to DC charger and connected the charger’s output to my 1000Ah AGM battery bank. I switched of engine detection set the aborption to 14,1V and the float to 13,5V. Input switch off at 10,5V restart at 11,0V It works perfect. My question. When will Victron start to supply a AC to DC regulator for windturbines?
battery charging
