petersailor avatar image
petersailor asked
REC BMS to Multiplus 12/1600/70
As there are no Aux inputs on this Multiplus 12/1600/70 how can I connect the REC BMS to this unit to control the charger on/off and the Inverter with the LiFePo4 battery bank?
MultiPlus Quattro Inverter ChargerBMS
You have one input, the temperature sensor.
Or you use a GX device and a Can.bus BMS.
petersailor answered ·
Thanks Matthias, I believe I need more than one input to control the charger and the Inverter cut-off?
It is also possible with one input. But it is not as good as with two inputs.
