Est ce que c’est possible de connecté le VE.bus smart dongle avec le Victron Phoenix multi 24/3000 70
Sinon avec quoi je peut connecter avec un mobile app. ?
There was a very similar question a few days ago.
https://community.victronenergy.com/questions/66836/phoenix-multiplis-123000120-firmware-update.html
and a few others more if you use the search function.
Thanks Mathias, so you would say yes but I may need to update the firmware.
IE. The Victron Phoenix multi 24/3000 70 has a Rj45 connection.?
First thing to check is what hardware version your device is.
The old small CPU (19 or smaller) is not compatible.
The newer large CPU (27 or grater) can be updated to the latest firmware.
To check this take off the front plate, at the main PCB is the CPU in the upper left.
On the CPU is a sticker with a 7 digit number XXXXYYY.HEX.
XXXX is the hardware ID and YYY the default firmware.
If the hardware ID starts with 19 or lower, your Multi is to old for the 4XX firmware.
https://community.victronenergy.com/answers/13509/view.html
21 People are following this question.
